transparent tunneling on cisco pix501
Is transparent tunneling enabled by default or do you have to config it?
If i use tcp 10000, i only have to creat 1 access-list to allow traffic in on that port right?
thanks.
travis.
  • Other Security Subjects
Silver
Re: transparent tunneling on cisco pix501
pix only use nat-t, which uses udp 4500. you do not need to open a hole for it in your ACL if you use "sysopt connection permit-ipsec"
It is not enabled by default. You need to:
isakmp nat-traversal 20
20 is the time between keepalives
i have the following..
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
when a vpn client connection is made, it always says that the transparent tunneling is inactive.
travis
Have you tried the fixup for IKE? Try this:
fixup protocol esp-ike
That's on v. 6.3(1) and newer...
PAT for ESP cannot be enabled since ISAKMP is enabled. Please correct your conf
iguration and re-issue the command!
that's what i got when i issued the fixup protocol esp-ike command. using version 6.3(1)
travis.
114
