transparent tunneling with vpn client and cisco 837
Hi, I'm trying to connect with a vpn client 4.0.2 that is behind an 837 adsl router. Althouh the ipsec connections gets stablished, there's no routing between the vpn client and the ipsec peer network.
Diagram:
VPN CLIENT=192.168.127.X
ADSL ROUTER=192.168.0.100 (cisco 837)
|IPSEC
|TUNNEL
REMOTE NETWORK=192.168.125.0 (cisco 837 ipsec hub)
The connection works well if I use a dialup ppp connection between the vpn client and the peer network.
NOTE: I'm transporting ipsec over udp, the route-map is avoiding PAT between peer ipsec networks.
1 REPLY
Silver
Re: transparent tunneling with vpn client and cisco 837
Hi Jordi,
Check with your ISP if they are off late blocking ESP.
86
