Trouble connecting to ASA5505 VPN
I have gone through the "VPN Wizard" selected remote access and set up a client machine outside of the network. When I try to connect I get the following error: " Secure VPN Connection Terminated locally by the Client. Reason 412.
Any help appreciated.
Green
Re: Trouble connecting to ASA5505 VPN
thomas, would you like to post the config?
names
interface Vlan1
mac-address 0012.3f7f.9876
nameif inside
security-level 100
interface Vlan2
description NuVox T1
nameif outside
security-level 0
ip address xxxx.170.18 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
dns domain-lookup inside
dns server-group DefaultDNS
domain-name amcinc.us
object-group icmp-type icmp_grp
icmp-object echo-reply
icmp-object information-reply
icmp-object traceroute
access-list out2in extended permit tcp any host xxxx.170.18 eq smtp
access-list out2in extended permit tcp any host xxxx.170.20 eq smtp
access-list out2in extended permit tcp any host xxxx.170.18 eq https
access-list out2in extended permit tcp any host xxxx.170.18 eq 9850
access-list out2in extended permit tcp any host xxxx.170.18 eq 1677
access-list out2in extended permit tcp any host xxxx.170.18 eq 7205
access-list out2in extended permit icmp any any echo-reply
access-list cisco_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 209.165.201.0 255.255.255.224
access-list inside_nat0_outbound extended permit ip any 192.168.1.0 255.255.255.0
access-list Cisco_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
mtu inside 1500
mtu outside 1500
ip local pool RemoteClientPool 209.165.201.1-209.165.201.20 mask 255.255.255.255
ip local pool ClientIPPool 192.168.1.100-192.168.1.149 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) xxxx.170.20 192.168.1.30 netmask 255.255.255.255
static (inside,outside) interface 192.168.1.50 netmask 255.255.255.255
access-group out2in in interface outside
route outside 0.0.0.0 0.0.0.0 xxxx.170.17 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy Cisco internal
group-policy Cisco attributes
dns-server value 64.89.70.2 64.89.74.2
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Cisco_splitTunnelAcl
default-domain value amcinc.us
username xxxx password xxx encrypted
username xxxxx password xxx encrypted privilege 15
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.114 255.255.255.255 inside
snmp-server host inside 192.168.1.1 community ASA5505
linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 60 set pfs
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
tunnel-group Cisco type ipsec-ra
tunnel-group Cisco general-attributes
address-pool RemoteClientPool
default-group-policy Cisco
tunnel-group Cisco ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh 192.168.1.110 255.255.255.255 inside
ssh 192.168.1.114 255.255.255.255 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.100-192.168.1.149 inside
dhcpd dns 64.89.70.2 64.89.74.2 interface inside
dhcpd enable inside
So I have run the vpn "remote" wizard and setup "Cisco" as a group and tunnel. Do I need to use "Cisco" as the group name in the VPN client? Or do I use the ID for the user that I set up in the VPN client? If it is the group name then what is the password, as I did not set up one on the ASA?
Green
Yes, Cisco would be the group name in the client. The password would be the "pre-shared key" under the attributes for the Cisco tunnel-group.
Ok,
I tried that with Cisco as the group name and the "pre-shared" key as the password. I still get the Reason: 412.
Windows firewall is running so I added cvpn to it and I am still having the problem.
Green
Post a show run sysopt.
Also, could you log on asa with debug crypto isakmp 7?
ASA5505# show run sysopt
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
sysopt connection permit-vpn
How do I "log on asa with debug crypto isakmp 7"?
kk did "debug crypto isakmp 7".
Green
"How do I "log on asa with debug crypto isakmp 7"?"
Depends how you are connecting to it...
console-
logging console debugging
telnet/ssh-
logging monitor debugging
ASDM-
debug crypto isakmp 7 from cli then launch monitor -> logging window
ASDM - Debug commands are not supported in CLI Window.
ssh - logging monitor = invalid input detected at monitor. Only option is savelog.
Green
asa# config t
asa(config)# logging monitor debugging
asa(config)# logging on
asa(config)# debug crypto isakmp 7
or just(I would do this one)
then use ASDM logging window
Ok have done that and I retried the connection. I stil get the Reason 412. And I do not see anything in that SSH window.
Green
How about the ASDM logging window, you see nothing from the vpn client? Is there another firewall in front of the ASA or anything which would be blocking vpn from the client?
No there are no other devices. I noticed when I re-ran the "VPN Wizard" that IKE defaults to DH Group 2. Should I set logging to group 2, or should I change the tunnel to use 7?
Green
dh group 2 has nothing to do with logging level 7.
asa# config t
Which ASDM window? The real time log viewer? If do I am not seeing any additional information.
also your vpn pool is the same as your LAN. to prevent ip address overlapping, it's recommended to use another ip subnet for vpn pool.
I see in in the ASDM Real Time Log Viewer set to debug level that the remote IP address for the pc that I am trying to VPN in is trying to talk to the internal SMTP server. Do I need additional vpn server software running internally or does the ASA5505 handle that?
I am still getting the 412. I built a new tunnel and password, still no luck.
Green
As city_index said, you should change your vpn client pool to another subnet, but this would not affect you establishing the vpn.
No, you do not need additional software. Is the client even getting prompted for username/password?
No, I don't get that far.
below is current running.
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
access-list inside_nat0_outbound extended permit ip any 209.165.201.0 255.255.255.224
access-list Amc_Reg_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
asdm image disk0:/asdm-522.bin
asdm history enable
arp timeout 14400
group-policy Amc_Reg internal
group-policy Amc_Reg attributes
split-tunnel-network-list value Amc_Reg_splitTunnelAcl
username xxx password Fa9pU7nHkZDmAvdG encrypted
username xxx attributes
vpn-group-policy Amc_Reg
username xxx password pfaW5bAu431sHznu encrypted privilege 15
username xxx password elxohIfKpfwEfs0V encrypted privilege 15
crypto dynamic-map outside_dyn_map 80 set pfs
crypto dynamic-map outside_dyn_map 80 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 100 set pfs
crypto dynamic-map outside_dyn_map 100 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 120 set pfs
crypto dynamic-map outside_dyn_map 120 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 140 set pfs
crypto dynamic-map outside_dyn_map 140 set transform-set ESP-3DES-SHA
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group Amc_Reg type ipsec-ra
tunnel-group Amc_Reg general-attributes
default-group-policy Amc_Reg
tunnel-group Amc_Reg ipsec-attributes
pre-shared-key *
telnet timeout 5
console timeout 0
dhcpd enable inside
Green
You can get rid of these, the vpn wizards keeps adding them in there...
no crypto dynamic-map outside_dyn_map 40 set pfs
no crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
no crypto dynamic-map outside_dyn_map 60 set pfs
no crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-SHA
no crypto dynamic-map outside_dyn_map 80 set pfs
no crypto dynamic-map outside_dyn_map 80 set transform-set ESP-3DES-SHA
no crypto dynamic-map outside_dyn_map 100 set pfs
no crypto dynamic-map outside_dyn_map 100 set transform-set ESP-3DES-SHA
no crypto dynamic-map outside_dyn_map 120 set pfs
no crypto dynamic-map outside_dyn_map 120 set transform-set ESP-3DES-SHA
no crypto dynamic-map outside_dyn_map 140 set pfs
no crypto dynamic-map outside_dyn_map 140 set transform-set ESP-3DES-SHA
The config look OK, can you try another client, another client version, another OS, is another vpn client installed on same machine?
the error you are getting is related to the asa not accepting your credentials your client is using. under cisco vpn client software, make sure under authentication the Name is exactly the same as the group name under the asa (one created by the vpn wizard) and also the preshared key as well. get the client to connect and monitor the traffic under asdm monitoring.
i suggest for monitoring any type of traffic to make it easier on yourself, use the cisco ASDM (all graphical). it provides different logging level and you can just about monitor anything.
Green
Green
In your vpn client config, the host address needs to be the outside interface of your asa. Is this what you have?
yes. I have the destination as the IP address for the outside interface.
ASA5505# show crypto isakmp sa
There are no isakmp sas
Is this an issue?
454
