Community Member
Trouble upgrading switch IOS inside my DMZ
Over the last couple of weeks, I have successfully upgraded the IOS on all my 2950's inside my LAN. Now I am moving on to a couple of switches inside my DMZ and I have run into a problem.
I can't do any kind of a tftp transfer.
I have configured the tftp service on my PIX 515e (ver. 6.3(3))
>tftp-server dmz x.x.x.x c:\tftp
But, I have not configured my LocalDirector tftp service.
Any ideas?
Thanks, Ben
Re: Trouble upgrading switch IOS inside my DMZ
The problem may due to firewall on the work station.
Disable the firewall on the workstation.
Community Member
It sounds like you have not allowed the tftp service to get through your PIX. What you have configured is the tftp location of where to propagate your PIX configuration, see the below link for usage:
I suggest you find out why the PIX is possibly blocking the tftp traffic going through. You can do this by increasing the logging levels on the PIX:
pix(config)# logging buffer debugging
Then try start the tftp.
Afterwards, look at the log files to see any indication of tftp being blocked by an ACL or NAT policy:
pix# show log
That probably does not exactly answer your question, however I hope that it helps you with the troubleshooting.
