Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
trouble with ACL
I have a doubt with some access list, I try this command in the interface outside but the interface didn't take the instruction.
access-list(access-list-name) extended deny tcp host 192.84.255.51 host(hostname) eq smtp
access-list(access-list-name) extended deny tcp host 192.84.255.51 host (hostname) eq https
I think that the two access-list don't working and the default access-list (deny any-any)
is the unique list good
Someone have any Idea?
thanks
Bronze
Re: trouble with ACL
I am a bit confused. How did you apply the ACL to the outside interface?
access-group name_of_acl in interface outside
rgds,
yeah, I apply the same access-group
Bronze
OK. So what is working and not working? You are not able to block those hosts from access smtp and https? Do you have other lines in your config? what is your log showing?
115
