Community Member
Trouble with CCA Pop Up
I have trouble trying to get clean access agent popup in the L2 OOB NAC deployment.
I'm using version 4.1.1.
My hosts will correctly get redirected to the CAS to download the CCA. But after installing the agent it doesnot get poppedup. (popped up is enabled)
I do not have a communication issue between the CAS and my hsosts. The UDP 8095 is open, and I'm able to ping bothways between CAS and client and no firewall in the client...
Can any one please give some advice on this?
Gemunu.
1 REPLY
Community Member
Re: Trouble with CCA Pop Up
I think you will need to uncheck "Enable L3 support". You may also try to reinstall the clean access agent.
129
