11-26-2007 11:21 AM - edited 02-21-2020 01:48 AM
Hi all,
I think I know the answer to my post but I would like a second opinion.
I am trying to trunk a Cisco 1200 AP to an ASA 5505. The AP must have a native VLAN on VLAN 1 according to this link:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43vlan.html#wp1038979
The ASA 5505 supports trunking but no native VLAN support.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/int5505.html#wp1057200 (see bottom of step 2).
Then I assume that if I want to do this, I'll have to put a switch in the middle, right?
The other option is to use a WLAN controller and tunnel all VLAN within the LWAPP tunnel.
Any other suggestions?
Martin
11-26-2007 11:32 AM
you are correct, that in trunking mode, there is no native vlan support.
Cisco makes some inexpensive switches that would probably suit your needs.
Log in to Community
