04-24-2006 09:09 AM - edited 03-09-2019 02:42 PM
I have two sites connected to the Internet using ADSL and dynamic IP´s.
Is there any way to configure a tunnel between the routers without using static IP´s?
Perhaps mapping an ip host to a domain name (using a dynamic DNS and ddns updates on the router),
and using that host as the tunnel destination. The tunnel would be used by ODR,
so it would not have to be up all the time nor for long periods of time.
If the IP address of one othe routers would change and drop the
tunnel, the other router could perform dns lookup to resolve the new IP.
Is this scenario possible? How would the config be?
I know that you can configure the tunnel destination using a domain name, but
it is replaced by the resolved ip address in the running config, so the router
would not perform a dns lookup the next time the tunnel is used (...and the ip address
would be outdated).
As always, any info will be much appreciated.
Eduardo
04-24-2006 09:31 AM
I think you need for you scenario TED (tunnel endpoint discovery) - it allows ipsec with dynamic addressed endpoints
check following link"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087a9a.html
M.
Hope that helps rate if it does
04-24-2006 10:37 AM
Thanks for your answer.
As I understood the document, TED helps you avoid configuring the static crypto maps (one for each peer), but does not help you find what address the peer has at the moment. The ip addresses are not assigned dynamically, as in my case. The problem with ADSL and dynamic IP´s is that the destination address changes once in a while.
Am I correct?
04-25-2006 12:06 AM
Hi unfortunately I don't think what you are looking for is possible. Depending of the sort of device you are using for terminating the VPN, It is possible to have one end using dynamic IP address but the hub needs to have a static one. A cisco router 1800 for example have the Easy VPN server feature which allows you to create a tunnel without knowing what the other end's IP is. But again the 1800 router itself needs to have a static IP.
04-27-2006 08:05 AM
Thanks, Fernando.
We´ll get a static address for the hub and possible go with either EasyVPN or IPSec TED.
Thanks for your help
Eduardo
