09-08-2006 06:35 AM - edited 03-09-2019 04:08 PM
hi, i have the problem that i want to reach a border-manager whith the vpn-client. for that i need protcol 57 (skip) going through the asa. i used a sniffer: i can see packets comming from the internet going through the asa to the border-manager. i can also see the packet's comming back to the internal interface of the asa but these packets never go through the asa - i cannot see them going out the external interface. there is nothing in the log.
what can i do?
regards dieter
09-14-2006 06:03 AM
What version of software are you using in the asa box ?
09-14-2006 09:41 PM
i use 7.2(1)(with failover).
i also took a look at the releasenotes of the interim versions... found nothing for that problem.
it's not so easy to update to an interim version because i need a lot of tests before...
do you have experience with the interim versions?
