Tunnel + Static NAT problem
Hi:
I've configured a Pix501 to establish a site-to-site tunnel with a 1710 in the central site and it works fine, except for one little problem. The central site hosts a Domino server which needs to have an static nat entry to allow servers in the internet to deliver mail to it. So, the problem is that although I created a route-map to avoid nat in site-to-site traffic, the static entry seems to takes precedence over the route-map and the mail server is always nated. So the SOHO can't access him. What can I do to solve this?
I need to use an entry like this:
ip nat inside static source tcp 172.16.34.22 1352 200.212.0.66 1352
Any help?
1 ACCEPTED SOLUTION
Bronze
Re: Tunnel + Static NAT problem
you need to do the following:
1) create a loopback interface with some ip subnet that you are not using anywhere in your network. Let;s say 10.10.10.0/30 :
int loop 0
ip address 10.10.10.1 255.255.255.252
2) create a route-map to match the traffic originated by the 172.16.34.22 server and destined to the other side of the tunnel
access-list 101 permit ip host 172.16.34.22 192.168.0.0 255.255.255.0
route-map static permit 10
match ip address 101
set ip next-hop 10.10.10.2 ( some address towards the loopback interface )
3) apply the route-map to the inside inteface of the router where you have the server
inter e0/0
ip policy route-map static
That's it
Hope that helps
Jazib
Bronze
int loop 0
inter e0/0
That's it
Hope that helps
Jazib
Thanks a lot, your answer was very helpfull. By the way, is there a page that shows a state machine of router processes? It will be really helpfull to know in wich order the router performs routing and nat steps.
Bronze
83
