two Crypto isakmp policies associatted to same crypto map
metzj
How do I map the second isakmp policy to the correct crypto map?
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp policy 2
encr aes 256
group 2
crypto isakmp key redmond address x.x.x.x
crypto isakmp key OregonVideo-08012005 address x.x.x.x
crypto isakmp key hillsboro address x.x.x.x
crypto isakmp key 123456789 address x.x.x.x
crypto ipsec transform-set ts esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set leds esp-aes 256
mode transport
crypto map salem-map 10 ipsec-isakmp
set peer x.x.x.x
set transform-set ts
match address 101
crypto map salem-map 20 ipsec-isakmp
description Gtech VPN Connection
set peer x.x.x.x
set security-association lifetime seconds 86400
match address 102
crypto map salem-map 30 ipsec-isakmp
set peer x.x.x.x
match address 103
crypto map salem-map 50 ipsec-isakmp
set peer x.x.x.x
set transform-set leds
match address 105
crypto map salem-map 50 I would like to associate isakmp policy 2.
Thanks for any suggestions
Jon Marshall
You don't map isakmp policies to crypto map entries. What happens is that your isakmp policies are tested in numerical order against the remote peer and if any of htme match then it moves onto phase 2 of the IPSEC tunnel.
Jon
