09-15-2006 12:33 PM - edited 03-09-2019 04:13 PM
If I use two global NAT command, how the PIX works to NAT or PAT ???
global (outside) 1 10.0.0.2-10.0.0.10 netmask 255.0.0.0
global (outside) 1 10.0.0.1 netmask 255.0.0.0
thanks.
09-15-2006 01:13 PM
This will NAT the first 9 users behind .2-.10, then when those 9 IPs are exhausted, it will PAT remaining users behind .1. For your reference:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/cmd_ref/gh_711.htm#wp1682258
09-15-2006 01:36 PM
Rico,
Rico,
Based upon your configuration, if you have a nat(inside)1 then the addresses from the inside will use Dynamic NAT and PAT.
When the inside addresses make outbound connections, they are translated using the global address pool of 10.0.0.2 - 10.0.0.10 as long as these addresses are available. If all the addresses in the pool are in use, then dynamic PAT takes place using the 10.0.0.1 address.
I hope it helps.
Arul
