Two ISP's running w/ NAT failover not working
I have two ISP's. They are not the same carrier or medium. T1 and Cablemodem. I have a 2621 router where I'm running NAT say 172.16.100.254 for the router IP. I have setup policy routing for my NAT pool, when I purposly pull my T1 which is the default route, I expect it to kick over to my cablemodem since I have a static route 0.0.0.0 0.0.0.0 cablemodem gateway 50 as the route. It does not work. I have to "clear ip nat translations *" before it starts working. Is there a timeout or bug in this? Or am I doing it wrong? My config is below
interface FastEthernet0/0
ip address xxx.xxx.122.1 255.255.255.240 secondary
ip address 172.16.100.1 255.255.255.0
ip nat inside
no cdp enable
interface Serial0/0
ip address xxx.xxx.26.58 255.255.255.252
description T1
ip access-group inbound-acl in
ip nat outside
no ip mroute-cache
service-policy input drop-inbound-http-hacks
no fair-queue
no cdp enable
interface FastEthernet0/1
description Cablemodem
ip address xxx.xxx.202.2 255.255.255.0
ip nat outside
speed 10
half-duplex
no cdp enable
ip nat pool cablewireless xxx.xxx.122.1 xxx.xxx.122.14 netmask 255.255.255.240
ip nat pool timewarner xxx.xxx.202.2 xxx.xxx.202.2 netmask 255.255.255.0
ip nat inside source route-map cablewireless pool cablewireless
ip nat inside source route-map timewarner pool timewarner
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.26.57
ip route 0.0.0.0 0.0.0.0 xxx.xxx.202.1 50
route-map timewarner permit 10
match ip address 1
match interface FastEthernet0/1
route-map cablewireless permit 10
match ip address 1
match interface Serial0/0
Any help would be appreciated!
Joe
jfinley@prcontrol.com
1 REPLY
Re: Two ISP's running w/ NAT failover not working
I think you need to add to your config:
ip nat translation timeout
The default is 86400 seconds (24 hours).
196
