Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
mak
Two routers in HSRP group in front of two PIXs, PIX in fail-over config.
If the PIX connected to Active router in HSRP group fails how communication will happen?
1 REPLY
Bronze
Re: Two routers in HSRP group in front of two PIXs, PIX in fail-
Assuming both of these routers are outside the PIX and connected to the SP. The PIX can only send its traffic to one default route OR it can listen (passively) to RIP updates. If you have RIP advertising these default routes to the PIX and one goes down, the other router should advertise itself as the new default route
142
