Community Member
two sa for a VPN connection? (Cisco VPN client 3.6.3 <--->IOS)
I open a VPN connection using CiscoVPN client 3.6.3 (behind a NAT) to a Cisco 3620 router, all works well, but when I use "sh crypto isakmp sa" command on the router, I see two couple of SA each associated with the same remote client! During the connection only one of the two association exchange data..What happens???
Follows a log of CISCO VPN client 3.6.3
79 12:22:50.777 03/30/03 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 10.0.0.1.
80 12:22:50.817 03/30/03 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID, VID, VID, VID, VID) to 10.0.0.1
81 12:22:50.817 03/30/03 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
82 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 10.0.0.1
83 12:22:51.188 03/30/03 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, VID, VID, VID, VID, VID, KE, ID, NON, HASH, NAT-D, NAT-D) from 10.0.0.1
84 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000059
Vendor ID payload = 12F5F28C457168A9702D9FE274CC0100
85 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
86 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000059
Vendor ID payload = AFCAD71368A1F1C96B8696FC77570100
87 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000001
Peer supports DPD
88 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000059
Vendor ID payload = B2BE6C300BEB39F6C45E0BE6E52E9FA7
89 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000059
Vendor ID payload = 09002689DFD6B712
90 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
91 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000059
Vendor ID payload = 90CB80913EBB696E086381B5EC427B1F
92 12:22:51.188 03/30/03 Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
93 12:22:51.218 03/30/03 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D) to 10.0.0.1
94 12:22:51.218 03/30/03 Sev=Info/5 IKE/0x63000071
Automatic NAT Detection Status:
Remote end is NOT behind a NAT device
This end IS behind a NAT device
95 12:22:51.238 03/30/03 Sev=Info/5 IKE/0x6300005D
Client sending a firewall request to concentrator
96 12:22:51.238 03/30/03 Sev=Info/5 IKE/0x6300005C
Firewall Policy: Product=Cisco Integrated Client, Capability= (Centralized Protection Policy).
97 12:22:51.238 03/30/03 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 10.0.0.1
98 12:22:51.238 03/30/03 Sev=Info/5 IKE/0x6300002F
99 12:22:51.238 03/30/03 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from 10.0.0.1
100 12:22:51.238 03/30/03 Sev=Info/5 IKE/0x63000044
RESPONDER-LIFETIME notify has value of 86400 seconds
101 12:22:51.238 03/30/03 Sev=Info/5 IKE/0x63000046
This SA has already been alive for 1 seconds, setting expiry to 86399 seconds from now
102 12:22:51.258 03/30/03 Sev=Info/5 IKE/0x6300005D
103 12:22:51.258 03/30/03 Sev=Info/5 IKE/0x6300005C
104 12:22:51.258 03/30/03 Sev=Info/4 IKE/0x63000013
105 12:22:51.258 03/30/03 Sev=Info/5 IKE/0x6300002F
106 12:22:51.258 03/30/03 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 10.0.0.1
107 12:22:51.258 03/30/03 Sev=Info/5 IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 10.0.0.138
108 12:22:51.258 03/30/03 Sev=Warning/3 IKE/0xE3000084
The length, 5338268, of the Mode Config option, , is invalid
109 12:22:51.258 03/30/03 Sev=Info/5 IKE/0xA3000016
MODE_CFG_REPLY: The received (32767) attribute and value (65280) is not supported
110 12:22:51.258 03/30/03 Sev=Info/5 IKE/0xA3000017
MODE_CFG_REPLY: The received (INTERNAL_ADDRESS_EXPIRY) attribute and value (86399) is not supported
111 12:22:51.258 03/30/03 Sev=Info/5 IKE/0x6300000E
MODE_CFG_REPLY: Attribute = APPLICATION_VERSION, value = Cisco Internetwork Operating System Software
IOS (tm) 3600 Software (C3620-IK9O3S7-M), Version 12.2(15)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 10-Mar-03 16:47 by ccai
112 12:22:51.258 03/30/03 Sev=Info/4 IKE/0xA3000015
MODE_CFG_REPLY: Received MODECFG_UNITY_SPLIT_INCLUDE attribute with no data
113 12:22:51.258 03/30/03 Sev=Info/5 IKE/0x6300000D
MODE_CFG_REPLY: Attribute = Recieved and using NAT-T port number , value = 0x00001194
114 12:22:51.268 03/30/03 Sev=Info/5 IKE/0x63000055
Received a key request from Driver for IP address 10.0.0.1, GW IP = 10.0.0.1
115 12:22:51.268 03/30/03 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 10.0.0.1
116 12:22:51.268 03/30/03 Sev=Info/5 IKE/0x63000055
Received a key request from Driver for IP address 10.10.10.255, GW IP = 10.0.0.1
117 12:22:51.268 03/30/03 Sev=Info/4 IKE/0x63000013
118 12:22:51.278 03/30/03 Sev=Info/5 IKE/0x6300002F
119 12:22:51.278 03/30/03 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ) from 10.0.0.1
120 12:22:51.278 03/30/03 Sev=Warning/3 IKE/0xA3000058
Received malformed message or negotiation no longer active (message id: 0x07676201)
121 12:22:51.568 03/30/03 Sev=Info/5 IKE/0x6300002F
122 12:22:51.568 03/30/03 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK QM *(HASH, SA, NON, ID, ID, NOTIFY:STATUS_RESP_LIFETIME) from 10.0.0.1
123 12:22:51.568 03/30/03 Sev=Info/5 IKE/0x63000044
RESPONDER-LIFETIME notify has value of 3600 seconds
124 12:22:51.568 03/30/03 Sev=Info/5 IKE/0x63000045
RESPONDER-LIFETIME notify has value of 4608000 kb
125 12:22:51.568 03/30/03 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH) to 10.0.0.1
126 12:22:51.568 03/30/03 Sev=Info/5 IKE/0x63000058
Loading IPsec SA (Message ID = 0x03C59714 OUTBOUND SPI = 0x2EF5A47A INBOUND SPI = 0x28D9CD3E)
127 12:22:51.568 03/30/03 Sev=Info/5 IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0x2EF5A47A
128 12:22:51.568 03/30/03 Sev=Info/5 IKE/0x63000026
Loaded INBOUND ESP SPI: 0x28D9CD3E
129 12:22:51.788 03/30/03 Sev=Info/5 IKE/0x6300002F
130 12:22:51.788 03/30/03 Sev=Info/4 IKE/0x63000014
131 12:22:51.788 03/30/03 Sev=Info/5 IKE/0x63000044
132 12:22:51.788 03/30/03 Sev=Info/5 IKE/0x63000045
133 12:22:51.788 03/30/03 Sev=Info/4 IKE/0x63000013
134 12:22:51.788 03/30/03 Sev=Info/5 IKE/0x63000058
Loading IPsec SA (Message ID = 0xA8B5AF91 OUTBOUND SPI = 0x13F0BE84 INBOUND SPI = 0xBB1FAC80)
135 12:22:51.788 03/30/03 Sev=Info/5 IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0x13F0BE84
136 12:22:51.788 03/30/03 Sev=Info/5 IKE/0x63000026
Loaded INBOUND ESP SPI: 0xBB1FAC80
137 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
138 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x63700010
Created a new key structure
139 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x6370000F
Added key with SPI=0x7aa4f52e into key list
140 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x63700010
141 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x6370000F
Added key with SPI=0x3ecdd928 into key list
142 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x63700010
143 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x6370000F
Added key with SPI=0x84bef013 into key list
144 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x63700010
145 12:22:52.139 03/30/03 Sev=Info/4 IPSEC/0x6370000F
Added key with SPI=0x80ac1fbb into key list
Bronze
Re: two sa for a VPN connection? (Cisco VPN client 3.6.3 <--->IO
There should be one IKE SA(sh cry isa sa), and two pairs of IPSec SAs(sh cry ips sa) per client.
Router side debugs would help in finding out the cause of it, and it could be a cosmetic issue if eveything is working ok.
Afaq
Community Member
Yes everything work ok, but when I issue the command "sh crypto ipsec sa" i see two sa related to the same identity with different SPI !
During data exchange only the first sa indicate a data exchange..
Community Member
Having multiple SA's between peers is common, so is having traffic counters against one of them.
The most common cause of multiple SA's are discontiguous address ranges or specific ports only covered in the crypto ACL's. It also occurs often in RAS and when using GRE/IPSec.
THe IPSec RFC is based around contiguous address ranges in the crypto ACL. So multiple SA's will be formed for SA's involving discontiguous hosts at each end.
Similarly, port/protocol based crypto ACL's, GRE/IPsec and, frequently RAS, will create multiple SA's although when you view the sa's only one of them has incrementing traffic counters.
The main thing is to take this into consideration when working out the maximum number of tunnels (or SA's) you want a device to terminate.
226
