Community Member
UDP 8905 traffic to default GW
I have NAC deployed in L2 OOB VGW mode and everything works fine. We see the FWSM , which has the L3 interface for the access VLAN, bombarded by UDP port 8905 traffic. I believe this is happening even after the PCs have changed to access VLAN (as I can see them in the online users list and their switchport is in Access VLAN. Is this normal and how can we stop it from happening? I have the discovery host set to default which is the CAM IP which ofcourse is on a separate subnet. Please let me know
Shaffeel
1 ACCEPTED SOLUTION
Re: UDP 8905 traffic to default GW
Shaffeel,
You are correct on both counts.
HTH,
Faisal
Shaffeel,
Agents are designed that way to send out traffic on port 8905 every 5 seconds. This is so when the agent is in the Auth VLAN, the CAS can 'sense' the agent and ask for authentication, so yes, it's a nuisance, but working as designed.
HTH,
Faisal
Community Member
Faisal
Thanks for your response. So just to confirm, even after authentication and posture assessment is complete, the agent tries to send these packets every 5 seconds? There is no way to stop this behaviour?
Shaffeel
Shaffeel,
HTH,
Faisal
3364
