Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UDP Encapsulation of IPSEC
Is it possible to encapsulate AH / ESP ( IPSEC) within UDP using NAT between 2 Cisco routers ?
Thanks in advance....
1 REPLY
Re: UDP Encapsulation of IPSEC
We can ONLY encapsulate IPSec traffic into UDP for Client to LAN Implementation for the CVPN3000 at this time.
For Site to Site implementations we donot need to do that, as the NAT operation happens before the IPSec happens and you can do NAT and then IPSec that traffic on the Routers, Sample to clear this concept can be found at: http://www.cisco.com/warp/public/707/same-ip.html
Hope this helps,
Aamir
285
