Unknown interface vlan on fwsm
ive done the ff. on the msfc
firewall module 2 vlan-group 1
firewall vlan-group 1 100,200,300
interface Vlan100
no ip address
interface Vlan200
no ip address
shutdown
interface Vlan300
no ip address
shutdown
BUT WHEN I DO THE FF ON THE FWSM
int vlan 300
i get the foloowing
FWSM# conf t
FWSM(config)# int vlan 300
Unknown interface vlan.
the fwsm is not recognizing my vlan. what is missing?
thanks
Hall of Fame Super Blue
Re: Unknown interface vlan on fwsm
Have you created the vlans at Layer 2 ie. if you do a "sh vlan" on the 6500 do you see your vlans ?
You do not create layer 2 vlans by entering
int vlan300
no ip address
shutdown.
If you want vlan 300 to be firewalled then please
1) remove the "interface vlan 300" from the 6500 ie.
6500(config)# no interface vlan 300
2) Add the vlan at layer 2 on the 6500 ie.
6500(config)# vlan 300
6500(config-vlan)# name vlan300
Do this for all vlans you want to firewall.
Jon
Router#sh firewall vlan-group 1
Group Created by vlans
1 FWSM 100,200,300
sh vlan
100 vlan100 active
200 vlan200 active
300 vlan300 active
but still the same on fwsm
FWSM(config)#
Is yout firewall running in single mode or multiple context mode ?
Jon
but on the fwsm sh vlan
FWSM# sh vlan
100, 200, 300
FWSM#
Jon
i was just running single mode initialy
FWSM Device Manager Version 4.1(5)
and i was just wondering why the nameif command is on the
FWSM(config)# nameif ?
Usage: nameif
no nameif [if_name] [security_lvl]
i was expecting it to be ion the interface mode
another thing, the fwsm OS looks like old one
FWSM Version 2.3(4)
JON...THIS IS AN IOS ISSUE...LUCKILYY I KNOW A BIT OF THE OLD PIX OS...IT WORKS BUT ILL LET CISCO UPGRADE IT...ITS HAVING PDM TOO
THANKS A LOT
687
