You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Unknown sniffed data from IDS sensor 4215
Hi all, when i snoop from my IDS, all the data i snoop was like the following... why is it like that?
anyone can help?
thanks!
? -> * ETHER Type=8100 (Unknown), size = 149 bytes
? -> * ETHER Type=8100 (Unknown), size = 212 bytes
? -> * ETHER Type=8100 (Unknown), size = 64 bytes
? -> * ETHER Type=8100 (Unknown), size = 594 bytes
  • Other Security Subjects
Bronze
Re: Unknown sniffed data from IDS sensor 4215
This basically indicates that frames being looked at are of a feature which is not supported. If you are running IOS 12.1, the reason would be that all the frames to the SPAN destination port come with 802.1Q tag which SNOOP does not support. You could use a sniffer to check the same.
8100 is the 802.1Q vlan tag type. Snoop does not understand vlan tagging. Try something like tcpdump and ethereal or some other "real" sniffer.
SC
PS. the IDS understands 802.1Q tagging...
On the same topic, what does the following sniffed data represent???
? -> (multicast) ETHER Type=0000 (LLC/802.3), size = 52 bytes
and
? -> (multicast) ETHER Type=2000 (Unknown), size = 388 bytes
159
