wkw
Upgrade IDS MC to use S57 knowledge base
Hi again,
I upgraded the signature + image file in a 4235 appliance to Version 4.1(1)S57.. subsequently i deleted the sensor from the IDS Management Center and added it back.. however it only gave me an option to identify the version as 4.0(1)S37 and below... no options for the later version...
How do i change the IDS Mgmt center to recognise and allow adding new sensor versions?
thanks
1 REPLY
Re: Upgrade IDS MC to use S57 knowledge base
Update the IDSMC to the latest version as well, i mean to 4.1.1.S57, and by the way try to discover the settings, do not manually add the sensor.
Here is where you can download and apply the new signature update to the IDSMC.
http://www.cisco.com/cgi-bin/tablebuild.pl/mgmt-ctr-ids-ids4updates
Nadeem
76
