03-21-2003 03:32 PM - edited 03-09-2019 02:37 AM
I currently have CSPM 2.3.3i on an NT server workstation. Does anyone know what I need to do to move the OS to Win2k? Do I need a new version of CSPM ? do I need to purchase a new product called Cisco Works VPN security Manager?
03-25-2003 01:04 PM
CSPM2.3.3i cannot run on Win2K. If you want to move to Win2K you will need to purchase VMS 2.1 and install the Management Console / Monitoring Centre for IDS.
FYI Included in VMS is CSPM 3.xf that is used for managing routers and PIX. This version now supports Win2K. It cannot be used for managing the IDS.
03-26-2003 07:53 AM
That's not entirely true. CSPM2.3.3i can run on Win2K, I've run it on a Win2K box. I do remember having to get past some obstacles in order to get it working. However, it's been several years now and I don't recall what those obstacles were.
03-26-2003 12:19 PM
Is the version of CSPM 2.3.3i or 2.3.3f?
03-26-2003 05:10 PM
2.3.3i is for managing IDS sensors, therefore the i in the name.
2.3.3f is for managing PIX Firewalls, therefor has the f in the name.
2.3.3i is only supported on Windows NT 4.0. It has not been tested on Win2K.
