Upgrade to 2.2.2a and 3.0 <from a sensor 2.2.0>
I recently took over the IDS systems at a client... their sigs and bases were 2.2.0 on some sensors,2.5 on others.
I upgraded the Unx Director to 2.2.2a w/ S3 sigs and One sensor from 2.2.0-->2.5<CD>-->3.0
I had two new sensors with 2.5 and upgraded them to 3.0.
I still have one more sensor thats 2.2.0 but with all custom sigs and filters...
My issue is that the Director can configure the 2.5-->3.0 sensors fine. But when it tries to open the 2.2.0-->2.5-->3.0 sensor, it does so only after displaying an error:
"unable to download the following files from 'sensorX' etc/smid.conf please ensure that your communication infrastructure between local and remote machine is functioning properly"
nrConns shows all communications established.
idsvers shows on the sensor all "v175"
I deleted and readded the sensor<as new> on the director but still get the same error. The config screen opens next and changes can be made however applying the changes never seems to occur and i eventually have to kill the ovw process on the director.
Other than the config piece, everything else went fine.
Is there something I missed or can check in regards to the etc/smid.conf error message?
many thanks
Re: Upgrade to 2.2.2a and 3.0 <from a sensor 2.2.0>
There are known issues when upgrading from 2.2.0 or 2.2.1 to 2.5 or 3.0.
The confugurations from the 2 versions are not compatible.
You will need to do the following:
1) Open the nrConfigure tool
2) Delete the entry for the current sensor
3) Run sysconfig-sensor Option 6 to create new configuration files on the sensor.
3) Select the Add Host wizard option and add the sensor as a New
sensor.
4) Redo any customizations for the sensor.
The DDTS Issue is: CSCdu10952
The Release Notes have other workarounds but because of the drastic upgrade in versions these other workarounds would be difficult to implement.
Thanks, Actually I did delete and readd it a second time(as a new sensor) and it worked fine. I suspect I either mistyped the naming of the sensor( _ not - ) when I first readded it OR I didn't actually add it as a new sensor...
As a followup test, I did my other 2.2.0 sensor today:
Going from 2.2.0-->2.5CD-->3.0 and then on the director's nrConfigure Tool, I deleted it and readded it as a new sensor.
..No problems whatsoever!
112
