Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Upgrading sensor signatures through CSPM
We are running CSPM version 2.3.3i. After upgrading the signature version to S11 on the CSPM. Is it possible to push the same S11 signatures from CSPM to all the sensors as well or we have to go to individual sensors and upgrade their signature manually.
Re: Upgrading sensor signatures through CSPM
The CSPM signature update only applies to CSPM host's NSDB htmls & signature template files.
The signature template files are backward compatible too.
The Wizards->Update Sensor option is only for showing up the updated sensor versions in CSPM
topology and to apply the updated signature templates.
U hv the sensor signature updates whichz a binary file for updating the netranger package in each
sensor. This cannot be pushed from CSPM.
This is correct, in that the Signature update Wizard
will only update the CSPM server and not your sensors. However, if you have multiple sensor, then
you may want to consider using the "idsupdate utility". With this utility you can store the sensor
updates on one ftp server(or a sensor) and then configure each sensor to automatically go to that ftp
site and download the signature update. This would save you from having to ftp the updates manually to each sensor.
Chris
Check out this url:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids6/12216_02.htm
98
