URFILTER
I have configured a 1700 series router with IOS 12.3(1a) and Firewall Feature Set to filter url requests to a Websense server.
Command 'show version' returned:
IOS (tm) C1700 Software (C1710-K9O3SY-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 06-Jun-03 19:50 by dchih
Image text-base: 0x80008120, data-base: 0x80F0625C
ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
******* uptime is 4 hours, 55 minutes
System restarted at 09:08:58 summer Thu Jul 17 2003
System image file is "flash:c1710-k9o3sy-mz.123-1a.bin"
cisco 1710 (MPC855T) processor (revision 0x200) with 55706K/9830K bytes of memory.
Processor board ID JAD06210391 (2582170859), with hardware revision 0000
MPC855T processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
1 Virtual Private Network (VPN) Module(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Command 'show startup-config' returned:
Using 4804 out of 29688 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname ********
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
enable secret
username
memory-size iomem 15
clock timezone UTC 3
clock summer-time summer recurring
ip subnet-zero
no ip source-route
no ip domain lookup
no ip bootp server
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip inspect name DEFAULT100 icmp
ip inspect name test http java-list 51 urlfilter timeout 30
ip urlfilter allow-mode on
ip urlfilter cache 1000
ip urlfilter server vendor websense 172.16.100.10 timeout 30
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ****************** address ******************
crypto ipsec transform-set ****************** esp-3des esp-md5-hmac
crypto map ****************** 1 ipsec-isakmp
set peer ******************
set security-association lifetime seconds 28800
set transform-set ******************
match address 100
interface Null0
no ip unreachables
interface Ethernet0
description $FW_OUTSIDE$
ip address ******************
ip access-group 104 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect DEFAULT100 out
ip route-cache flow
half-duplex
no cdp enable
crypto map AG-Moscow
interface FastEthernet0
description $FW_INSIDE$$ETH-LAN$$ETH-SW-LAUNCH$
ip address 172.16.75.2 255.255.255.0
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip inspect test in
ip route-cache flow
speed auto
no cdp enable
ip nat inside source route-map nonat interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 ******************
ip http server
ip http authentication local
ip http secure-server
access-list 51 permit any
access-list 100 permit ip 172.16.75.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 101 deny ip 172.16.75.0 0.0.0.255 172.16.100.0 0.0.0.255
access-list 101 permit ip 172.16.75.0 0.0.0.255 any
access-list 102 permit tcp host ****************** any eq telnet
access-list 102 permit esp any any
access-list 102 permit udp any any eq isakmp
access-list 102 permit icmp any any
access-list 102 permit tcp 172.16.100.0 0.0.0.255 any eq telnet
access-list 102 permit tcp 172.16.100.0 0.0.0.255 any eq 5900
access-list 102 permit udp host 128.227.205.3 any eq ntp
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 deny ip****************** any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 permit ahp host ****************** host ******************
access-list 104 permit esp host ****************** host******************
access-list 104 permit udp host ****************** host ****************** eq isakmp
access-list 104 permit udp host ****************** host ****************** eq non500-isakmp
access-list 104 permit ip 172.16.100.0 0.0.0.255 172.16.75.0 0.0.0.255
access-list 104 deny ip 172.16.75.0 0.0.0.255 any
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip host 0.0.0.0 any
access-list 104 deny ip any any log
no cdp run
route-map nonat permit 10
match ip address 101
line con 0
login local
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
scheduler interval 500
ntp clock-period 17179653
ntp server 128.227.205.3
end
When I check the status of the url filtering by entering "sh ip urlfilter config", I get this,
Websense URL Filtering is DISABLED
Primary Websense server configurations
Secondary Websense servers configurations
Websense server IP address: 172.16.100.10
Websense server port: 15868
Websense retransmission time out: 30 (in seconds)
Websense number of retransmission: 2
Other configurations
Allow Mode: ON
System Alert: ENABLED
Audit Trail: DISABLED
Log message on Websense server: DISABLED
Maximum number of cache entries: 1000
Maximum number of packet buffers: 200
Maximum outstanding requests: 1000
I cannot understand why Websense URL filtering is disabled.
Anyone help please?
1 REPLY
Silver
Re: URFILTER
The problem seems to be with applying the rule to the interface. You have applied the rules with the name 'test' (ip inspect test in which is not defined in your configuration. Please see the doc 'Firewall Websense URL Filtering' at
"http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide09186a0080146556.html#1027188"
119
