Urgent help: ISDN backup for VPN -- Router configs
Would anyone care and have a look at the configs of the routers and tell me what's wrong? I described the task I'm trying to solve and the problems in a previous message.
I'll greatly appreciate it.
router 1
version 12.2
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname r1
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
username r2 password 7 XXXXXX
ip subnet-zero
interface Tunnel1
ip address 192.168.3.1 255.255.255.0
ip mtu 1440
tunnel source 117.27.36.229
tunnel destination 117.27.34.230
interface Ethernet0/0
ip address 117.27.36.221 255.255.255.248
no ip redirects
no ip proxy-arp
half-duplex
no cdp enable
interface Serial0/0
bandwidth 512
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type q933a
interface Serial0/0.1 point-to-point
bandwidth 512
ip address 117.27.36.229 255.255.255.252
no cdp enable
frame-relay interface-dlci 20 IETF
interface BRI1/2
no ip address
encapsulation ppp
no logging event link-status
dialer pool-member 5
isdn switch-type basic-net3
isdn incoming-voice data
no cdp enable
interface Dialer3
description Remote access
ip address 192.168.10.2 255.255.255.0
encapsulation ppp
ip ospf cost 9999
dialer pool 5
dialer string 1111111
dialer-group 2
no peer neighbor-route
no peer default ip address
pulse-time 0
no cdp enable
ppp authentication pap
ppp pap sent-username r1 password 7 XXXXXXXXXX
router ospf 100
no log-adjacency-changes
network 192.168.3.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 0
network 217.27.36.216 0.0.0.7 area 0
ip route 0.0.0.0 0.0.0.0 Serial0/0.1
ip route 0.0.0.0 0.0.0.0 Dialer3 200
ip route 192.168.10.3 255.255.255.255 Dialer3
no ip http server
ip pim bidir-enable
access-list 120 deny ospf any any
access-list 120 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip list 120
router 2
version 12.2
hostname r2
aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.1.5.0 10.1.5.15
ip dhcp excluded-address 10.1.5.250 10.1.5.255
ip dhcp pool dyn
network 10.1.5.0 255.255.255.0
default-router 10.1.5.251
netbios-node-type h-node
netbios-name-server 10.1.1.200
domain-name aeolos.com
dns-server 119.237.32.197 119.237.32.196
lease 0 1
ip ssh time-out 120
ip ssh authentication-retries 3
crypto isakmp policy 10
authentication pre-share
lifetime 72000
crypto isakmp policy 11
encr 3des
lifetime 3600
crypto isakmp key XXXXXXX address 117.27.36.222
crypto ipsec transform-set nichqset ah-sha-hmac esp-des
crypto map cmap 12 ipsec-isakmp
set peer 117.27.36.222
set security-association lifetime seconds 72000
set transform-set nichqset
match address 102
interface Tunnel0
ip address 192.168.3.2 255.255.255.0
ip mtu 1440
tunnel source 117.27.34.230
tunnel destination 117.27.36.229
description Local Area Network
ip address 10.1.5.251 255.255.255.0
ip nat inside
rate-limit output 128000 16000 16000 conform-action set-prec-transmit 1 exceed-action set-prec-transmit 0
half-duplex
interface Serial0/0
description Frame Relay Link
bandwidth 512
no ip address
no ip route-cache
no ip mroute-cache
no fair-queue
frame-relay traffic-shaping
description PVC to Anywhere
bandwidth 512
ip address 117.27.34.230 255.255.255.252
ip nat outside
no ip route-cache
no ip mroute-cache
no arp frame-relay
no cdp enable
frame-relay class frl
crypto map cmap
interface BRI0/0
description Remote access for Limassol Office 25 818410
no ip address
encapsulation ppp
no fair-queue
no cdp enable
interface Dialer0
ip address 192.168.10.3 255.255.255.0
encapsulation ppp
no ip route-cache
ip ospf cost 9999
no ip mroute-cache
dialer pool 1
dialer remote-name r1
dialer string 1111111111
dialer hold-queue 10
dialer watch-group 10
dialer-group 2
no fair-queue
no cdp enable
ppp pap sent-username r2 password XXXXXXXXXX
crypto map cmap
router ospf 100
ip nat inside source route-map nonat interface Serial0/0.1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 117.27.34.229
ip route 0.0.0.0 0.0.0.0 Dialer0 200
ip route 192.168.10.0 255.255.255.0 Dialer0
ip route 117.27.32.0 255.255.240.0 Serial0/0.1
no ip http server
map-class frame-relay frl
frame-relay traffic-rate 256000 512000
frame-relay adaptive-shaping becn
access-list 100 permit ip host 10.1.1.1 any
access-list 102 permit ip 10.1.5.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 120 deny ip any any
access-list 130 deny ip 10.1.5.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 130 permit ip 10.1.5.0 0.0.0.255 any
dialer watch-list 10 ip 117.27.36.216 255.255.255.248
route-map nonat permit 10
match ip address 130
Re: Urgent help: ISDN backup for VPN -- Router configs
Your configs don't seem to be correct.
First of all there is no IPSec configuration on router1 ??
router2 is peering with 117.27.36.222, which router is this, it it router1 ???? doesn't look like! are you doing IPSec b/w these 2 routers ??
Anyways, you can use following URL as a template to achieve your objective
http://www.cisco.com/warp/public/707/ipsec_dialerwatch.html
R/Yusuf
That's the whole difficulty I'm facing. router 1 is not doing IPSec with router 2.
A PIX behind router 1 is doing IPSec with router 2.
The configs are correct, as IPSec is operational.
The URL you mentioned, doesn't apply to my case because of PIX and NAT
Thanx anyhow.
232
