Urgent!! interswitch FWSM failover fail
We have do some redundant & failover test ( please reference attachment ) :
1. shutdown Catalyst 6513-A FWSM, the failover test is ok
2. bring up Catalyst 6513-A FWSM, then use "failover active" command to switchover, the failover test is ok
3. use "show redundant" IOS command to verify Catalyst 6513-A SUP720 redundant status is ok, use "show failover" FWSM command to verify both FWSM failover status is ok, then we remove Catalyst 6513-A active SUP720, it switchover to another SUP720, and Catalyst 6513-A & Catalyst 6513-B L2 connection is ok, access to Catalyst 6513-C & Catalyst 6513-D and clients below them are ok, but access through FWSM fail, ping to FWSM interface fail ( wait more than 5 mins after remove SUP720 ). the FWSM failover command when network connection fail :
Failover On
Failover unit Primary
Failover LAN Interface faillink Vlan 252
Unit Poll frequency 5 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds
Interface Policy 1
Monitored Interfaces 3 of 250 maximum
failover replication http
Config sync: active
Last Failover at: 16:38:31 Nov 19 2005
This host: Primary - Active
Active time: 995 (sec)
Interface pacs (10.100.254.1): Normal (Waiting)
Interface his (10.100.250.1): Normal (Waiting)
Interface dj (10.100.253.1): Normal (Waiting)
Other host: Secondary - Failed
Active time: 1205955 (sec)
Interface pacs (10.100.254.2): Normal
Interface his (10.100.250.2): Normal
Interface dj (10.100.253.2): Normal
Stateful Failover Logical Update Statistics
Link : statelink Vlan 251
Stateful Obj xmit xerr rcv rerr
General 160623 0 162151 0
sys cmd 160617 0 160614 0
up time 0 0 0 0
RPC services 0 0 0 0
xlate 0 0 0 0
TCP conn 11 0 8231 0
UDP conn 0 0 0 0
ARP tbl 6 0 1537 0
RIP Tbl 0 0 0 0
L2BRIDGE Tbl 0 0 0 0
Xlate_Timeout 0 0 0 0
TCP NPs 1910 0 1950167 19594
UDP NPs 199 0 52853 19594
Logical Update Queue Information
Cur Max Total
Recv Q: 0 3 162151
Xmit Q: 0 2 160623
Attachment are show tech ( during normal state ) & network diagram. Can you advise me to resolve this problem?
Best Regards,
Silver
Re: Urgent!! interswitch FWSM failover fail
hi,
when you failover to secondary SUP, do you have communication between the SUP and FWSM IPs? have you tried to clear arp? what does show arp says on both?
No, I can not ping FWSM IPs from SUP720 when failover to secondary SUP720. I have not try to clear arp and show arp to identify the arp table.
I have try to ping througth FWSM, not always timeout, but very few packet pass. Is it possible both FWSM in active state after SUP720 failover? Does the Cat6513 & FWSM configuration and network diagram correct?
Best Regards,
Silver
We dont know which one of the FWSM was active? It is possible that both FWSM goes in active state, but if FWSM communicates through a vlan that is not broken, it shouldnt happen.
thanks
Nadeem
When the second SUP720 become active, can you check whether the local FWSM is active?
Try bring down the FWSM on the switch with newly elected/active SUP720 and check (ping) whether clients connected to vlan his (vlan 255) & vlan dj (vlan253) can still ping the vlans interface IPs? Successful ping may indicates the FWSM on the Cat with inactive SUP720 is active.
Maybe you need to configure hsrp (with priority) on vlan254 on the both SUP720s and configure interface pacs on FWSM with ospf as well so that if vlan254 on 1st SUP720 is detected as down or SUP720 being pulled out, the second SUP720 will take over together with hsrp and ospf update on both FWSMs.
Rgds,
AK
FYI, i have almost similar setup with yours.
- 2 x Cat6513 with SUP2 and FWSM (v2.2(1))
- hsrp
- ospf
The HSRP and FWSM failover between Cat6513 works fine
After second SUP720 become active, the local FWSM is active, but failover status is not ok
Failover On
Interface Policy 1
Config sync: active
up time 0 0 0 0
xlate 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 6 0 1537 0
RIP Tbl 0 0 0 0
Cur Max Total
Recv Q: 0 3 162151
Xmit Q: 0 2 160623
After we bring down the FWSM on the switch with newly elected/active SUP720 to switch active state to FWSM in another Catalyst 6509, the network connection, so I think this is not ospf problem, maybe the problem is after SUP720 switchover, both FWSM in active state. ( But the L2 connection between 2 Catalyst 6509 is ok??? )
Best Regards,
Can you post config for standby FWSM? I have seen this problem before when I first deploy my FWSM. Both of the blades are in active-active mode.
Rgds,
AK
FYI. But before SUP720 switchover, the FWSM failover status is ok, and simple FWSM failover test ( shutdown Active FWSM ) is ok.
Best Regards,
Can you give me your email address? Maybe I can send you my full config.
Rgds,
AK
My email address : jackson_ku@mikotek.com.tw
Is there any different with your configuration?
Best Regards,
Jackson Ku
Failover On
Interface Policy 1
Config sync: active
up time 0 0 0 0
xlate 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 6 0 1537 0
RIP Tbl 0 0 0 0
Cur Max Total
Recv Q: 0 3 162151
Xmit Q: 0 2 160623
After we bring down the FWSM on the switch with newly elected/active SUP720 to switch active state to FWSM in another Catalyst 6509, the network connection is ok, so I think this is not ospf problem, maybe the problem is after SUP720 switchover, both FWSM in active state. ( But the L2 connection between 2 Catalyst 6509 is ok??? )
Best Regards,
This is the partial config of my active FWSM. But as you said, it could be due to SUP as well. Will post it later.
796
