URL Redirect Feature when using L2 NAC with 802.1X
I cannot seem to find a way to Re-direct HTTP Traffic (For Non-Healthy) hosts when using 802.1X NAC (Its works fine with L2 IP NAC and L3 NAC).
Using 3560 Switch I can put the Non-Healthy Hosts into a Quarantine VLAN but Is there a way to Redirect the HTTP traffic from hosts, so that they can be taken to the remediation page ?
url-redirect attribute doesn't work.
Naman
1 REPLY
Re: URL Redirect Feature when using L2 NAC with 802.1X
802.1x NAC doesn't support URL Redirect.
What you need to do is include the prompt message to inform user access which particular server for AntiVirus Patch or Remediation Server.
Of course the Server must locate at Quarantine vlan.
135
