Community Member
USB slot in ASA 5520
I have inserted a USB flash inside usb slot in ASA5520, but I can not access the usb. I know in the routers if I do "sh usb" I can see the content, but what is the command in ASA 5520 to access USB? I am running ASA 8.2(1)
1 REPLY
Re: USB slot in ASA 5520
According to the 8.x documentation, it is for "future use". Taking from that, there are probably no commands for accessing the USB drive (or they are hidden commands).
Hope that helps.
2996
