Use internal DHCP sever for remote VPN client ?
Hi, I am configuring my PIX to be a vpn server and i use cisco vpn client 4.8. does PIX support to relay the dhcp request from vpn client to my internal DHCP server? or I have to use local dhcp pool on pix? If can, what's the command? I search cisco web but no result!
1 REPLY
Re: Use internal DHCP sever for remote VPN client ?
Hi yes you can ... but you need to configure it as part of the AAA authorization set up. If you use ACS for AAA then you can find help on the ACS 3.2 admin guide ... search for 'Setting IP Address Assignment Method for a User Group' below is the link
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_user_guide_book09186a0080205707.html
I hope it helps .. please rate it if it does !!!
104
