03-26-2008 09:16 AM - edited 03-09-2019 08:22 PM
apparently I have a global range defined on my outside interface, suggestion is to use a pat statement to replace this. looking for guidance
thank you
03-26-2008 01:43 PM
Hi Mark
All you have to do is defining 1 single IP entry or the interface itself in the following section
global (outside) x ipaddresshere or
global (outside) x interface
03-28-2008 06:59 AM
so basicaly a
global (outside) id ousideip.2-outsideip.7 netmask x.x.x.x can be replaced with
global (outside) id outsideip.2
03-28-2008 08:00 AM
Exactly. If it fails, try
global (outside) id outsideip.2 netmask 255.255.255.255
05-02-2008 02:48 AM
try with this config
for Example
nat (inside) 1 172.16.0.0 255.255.0.0
global (outside) 1 "outside Ip"
hopes this helps
regs
S.Mohana sundaram
