Does AAA authentication from the outside to inside only work on port 80?
I've configured the PIX 525 (6.2) to allow an incoming connection on port 5800 and 80 to a specific IP address for which a static exists. I've also configured AAA authentication for that connection.
The port 80 connection works fine once a valid username and pw have been entered, and then I can then access the address on port 5800. But if I clear the uauth then try and connect to 5800 first I get the VNC logon but can't get any further and I'm not prompted for a username and pw.
So if I connect to port 80 first all is ok but if I try and connect to 5800 first the connection fails.
