Using ASA as SSL VPN client
I have a few home users who have an ASA 5505 setup to use the EZVPN client to connect back to our headquarters, providing them "on-net" experience with real phones (instead of softphones). We're moving to a new hosted VPN service for traveling users, and the carrier is using an SSL VPN. Is there anyway to get my 5505s to connect to that service as well? Thanks.
1 REPLY
Silver
Re: Using ASA as SSL VPN client
You can do the Auto Sign-on through Smart Tunnel. If you need SSL VPN - then choose webvpn & SSL VPN. If you need only webvpn, then use only webvpn. With regard to java info of port-forwarding, check if the list is being used in the group-policy.
While the smart tunnel now allows Java applet to work for some application, single sign on no longer works for it. Try creating a bookmark for the application and enable the ST option. This is a Smart Tunnel limitation.
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a008017b2a4.shtml
453
