Using ASDM for failover setup - GTP/GRPS Fails?
I'm trying to setup 2 ASA5520 in active/passive failover using the ASDM wizard, but during the tests it reports: License combatibility test for GTP/GPRS failed (Disabled, Disabled)
Suggestions?
Re: Using ASDM for failover setup - GTP/GRPS Fails?
Can you do a show version command and post the result please.
CiscoASA(config)# sh ver
Cisco Adaptive Security Appliance Software Version 7.2(1)
Device Manager Version 5.2(1)
Compiled on Wed 31-May-06 14:45 by root
System image file is "disk0:/asa721-k8.bin"
Config file at boot was "startup-config"
CiscoASA up 1 day 5 hours
Hardware: ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 64MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x
Boot microcode : ☻CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: ♥CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : ☺CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0 : address is 0018.1900.1110, irq 9
1: Ext: GigabitEthernet0/1 : address is 0018.1900.1111, irq 9
2: Ext: GigabitEthernet0/2 : address is 0018.1900.1112, irq 9
3: Ext: GigabitEthernet0/3 : address is 0018.1900.1113, irq 9
4: Ext: Management0/0 : address is 0018.1900.1114, irq 11
5: Int: Not licensed : irq 11
6: Int: Not licensed : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 750
WebVPN Peers : 2
This platform has an ASA 5520 VPN Plus license.
Hi .. Can you post a show ver from both ASAs
I have the same problem, with the same version. I have configured failover manually.
327
