Using BGP over DMVPN
rmaerz
Anyone have config examples for configuring BGP over a DMVPN network, if it's even possible?
6 Replies 6
Marwan ALshawi
if u use IBGP it will work but EBGP dosnt unless u advetise all the tuneel links, because with DMVPN u need to advertise the tunnel interface so when the spokes rigister with hub the hub will be able to point the first packet coming from newly rigistered spoke to other spoke then subsequent packet will be direct spoke to spoke
good luck
if helpful Rate
Marwan ALshawi
good luck
if helpful Rate
Marwan ALshawi
good luck
if helpful Rate
Nice, but configs would be helpful
what topology u look for
let me know how and which IGP and so on to let me know the required config
Marwan ALshawi
good luck
if helpful Rate
