Using CCA Stub to Launch an Executable (For Non-Admins)
Has anyone successfully launched a qualified\digitally signed executable using CCA Stub (When the logged User is Non-Administrator) ?
I have followed all the instructions to create a signed executable using our internal CA but CCA Stub is unable to launch the executable.
I then tried with a Microsoft Signed executable (To Rule out any error with our CA) but still the same result.
The only message that comes up is "Cisco Clean Access Agent stub failed to launch. <executable name>".
If I login as Administrator then the launch works fine but ofcourse this launch is not using the CCA Stub since logged User is Admin.
Naman
Re: Using CCA Stub to Launch an Executable (For Non-Admins)
I did not used a signed version of the executable and it's working fine. The only thing I can say though is make sure you are using the agent version right from the CAS (when you go through the web NAC authentication portal). Don't use the agent version from Cisco.com "Download Software" section because the exec il altered by the CAS. Use the one from the CAS.
Email from Cisco TAC:
Dominic,
Can you please tell me where the agent is being downloaded from? To work with the stub, it should be downloaded from the CAS, and not from cisco.com. This is because the agent downloaded from the CAS will have certain necessary site specific information.
My two cents...
Hi Dominic,
Thanks for the response. I am actually using the CCA version from the CAS (That i installed through Web Remediation). I then downloaded the CCAStubMSI from CAM Admin interface and copied it to the Host PC and then installed it.
Still when I login as Non-Admin User, it fails to launch the defined executable through CCAStub.
Any ideas ?
Do I need to download the Stub also from CAS ? If Yes, then from which location ?
Can you send me in private the TAC Engineer info, who handled your case ? I will the try to have my case transferred to him.
Naman
246
