Using Cisco Client behind a Sonicwall firewall
I am wanting to use my cisco client 3.5 to access an authentication server on our customers network for administration duties.
I am using client 3.5 going through a Sonicwall Pro 300 firewall set for NAT and connecting to a 3005 concentrator which then authenticates the user via a a Radius Server.
I am able to authenticate from the client but am unable to use terminal services,vnc,telnet or even ping the destination server.
Where as when I use a dial-up connection via 3rd Party ISP I can authenticate and access the Radius server via terminal services etc etc.
I looked at the Sonicwall firewall to see if ipsec passthrough was available but unable to find it.
I find it strange that I can authenticate (establishing the tunnel) on my internal lan, but no do anything else.
I am assuming it has something to do with the sonicwall.
here is the path i am trying to achieve.
Cisco client-sonicwall-3005 concentrator-cygberguard firewall-authentication server.
Thanks in advance
Andy
Silver
Re: Using Cisco Client behind a Sonicwall firewall
Is the nat traversal feature enabled on the 3005? That will wrap the ipsec packets in udp to work behind NAT.
Thanks for the response.
So I am assuming that Nat traversal does not need to be enabled for the authentication phase as I am able to do this.
114
