We are planning to use NAC to check the security patch level\hot fixes etc at the end-point and then perform "automated remediation".
Many products that i looked at involve some level of User-Interaction to perform remediation\apply fixes etc. Is there a product that does the remediation while being transparent to the user ? (The user will just be informed of the Non-Healthy Posture but he will not be asked to click any buttons etc).
Naman
