Using Radius with Expiry on an ASA 5520
dpatkins
I would like to know where I would assign the Radius with Expiry on an ASA for a VPN group? Can this be done on ADSM as well?
Dwane
acomiskey
Level 10
Level 10
I believe it is now called "password-management".
Yes, it can be done in the ASDM.
Config -> VPN -> edit tunnel group -> General/Basic Tab
check "enable notification upon password expiration to allow user to change password"
Please rate helpful posts.
acomiskey
Level 10
Level 10
I am looking at this ADSM and I am using 6.0 with 8.02 IOS on the ASA 5520. I do not even see a tunnel-group on the Remote VPN tab.
I will continue looking. I would even be happy with the CLI command.
Dwane
I did find it on ADSM 6.0. Here is the section.
It is Remote Access VPN-> IPSec Connection Profiles->Advanced->General.
And it is Password management now.
Thanks again for your help.
Dwane
The cli command is "password-management".
Glad it helped. I've never been able to get the part to work where it notifies you your password will expires in x days. But I have been able to change my password once it expired.
