12-21-2007 05:56 AM - edited 02-21-2020 03:26 PM
Hi all.I have a rather strange situation regarding site-to-site VPN tunnel.
On one end I have a PIX 501 and on the other end an ASA5505 and a tunnel set up between them.
The problem is that from the side of the PIX I cannot establish a tunnel but when the traffic start from the ASA's side the tunnel establishes as normal.
I have checked the configurations on both ends and keys, passwords, mirror ACLs seem OK. The only thing that springs to attention is that I have the same transform set used for 2 different tunnels on the PIX side.
Can I use the same transform set on multiple tunnels or should I define a different transform set for every tunnel? Could this be the source of the problem?
Solved! Go to Solution.
12-27-2007 11:54 AM
Use this on PIX
crypto map
Or on ASA, use :
crypto map
12-21-2007 08:25 AM
No that won't be an issue. I have used the same transform set on a pix for over 60 site-to-site VPN tunnels.
What does the debugging show ?
Jon
12-24-2007 02:22 AM
Here are the results of the debugging on both sides of the tunnel. I was out of action for a couple of days so sorry for the late reply.
ASA side:
Dec 20 12:24:27 [IKEv1]: Group = x.x.x.x, IP = x.x.x.x, QM FSM error (P2 struct &0x3a81b50, mess id 0x4bf27953)!
Dec 20 12:24:27 [IKEv1]: Group = x.x.x.x, IP = x.x.x.x, Removing peer from correlator table failed, no match!
PIX side:
ISAKMP (0): beginning Main Mode exchange
crypto_isakmp_process_block:src:x.x.x.x, dest:y.y.y.y spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 10 policy
ISAKMP: encryption DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 1
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (basic) of 7200
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): received xauth v6 vendor id
ISAKMP (0): speaking to another IOS box!
ISAKMP (0): speaking to a VPN3000 concentrator
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): SA has been authenticated
ISAKMP (0): beginning Quick Mode exchange, M-ID of -245075964:f1647004
ISAKMP (0): processing NOTIFY payload 14 protocol 3
spi 0, message ID = 1293387221
return status is IKMP_NO_ERR_NO_TRANS
ISAKMP (0): processing DELETE payload. message ID = 3694378254, spi size = 16
ISAKMP (0): deleting SA: src y.y.y.y, dst x.x.x.x
ISADB: reaper checking SA 0xad3ac4, conn_id = 0 DELETE IT!
VPN Peer:ISAKMP: Peer Info for x.x.x.x/500 not found - peers:2
ISADB: reaper checking SA 0xaec8dc, conn_id = 0
ISADB: reaper checking SA 0xaebd5c, conn_id = 0
ISADB: reaper checking SA 0xae6f2c, conn_id = 0
I can also post the related parts of configs from both sides.
12-25-2007 03:36 PM
Can you please post the relevant part of the config and the debugs for ipsec as well.
deb cry ipsec
12-27-2007 08:13 AM
Here are the relevant parts of the configs from both devices.
ASA side:
crypto ipsec transform-set cp esp-des esp-sha-hmac
crypto ipsec security-association lifetime seconds 3600
crypto map vpn 20 match address 120
crypto map vpn 20 set pfs
crypto map vpn 20 set peer x.x.x.x
crypto map vpn 20 set transform-set cp
crypto map vpn interface outside
isakmp identity address
isakmp enable outside
isakmp policy 2 authentication pre-share
isakmp policy 2 encryption aes-256
isakmp policy 2 hash sha
isakmp policy 2 group 5
isakmp policy 2 lifetime 86400
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 7200
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
pre-shared-key xxxxxxxxxxxxxxxxx
access-list 120 extended permit ip 172.20.8.0 255.255.255.0 172.20.9.0 255.255.255.0
access-list 120 extended permit ip 10.100.8.0 255.255.255.0 172.20.9.0 255.255.255.0
access-list 120 extended permit ip 10.100.16.0 255.255.255.0 172.20.9.0 255.255.255.0
PIX side:
crypto map vpn 20 ipsec-isakmp
isakmp key xxxxxxxxxxxx address x.x.x.x netmask 255.255.255.255
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash sha
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
access-list 120 permit ip 172.20.9.0 255.255.255.0 172.20.8.0 255.255.255.0
access-list 120 permit ip 172.20.9.0 255.255.255.0 10.100.8.0 255.255.255.0
access-list 120 permit ip 172.20.9.0 255.255.255.0 10.100.16.0 255.255.255.0
12-27-2007 08:15 AM
Forgot the debug of ipsec.
IPSEC(key_engine): got a queue event...
IPSEC(spi_response): getting spi 0x9b7d0784(2608662404) for SA
from y.y.y.y to x.x.x.x for prot 3
IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
IPSEC(key_engine_delete_sas): delete all SAs shared with y.y.y.y
IPSEC(key_engine): request timer fired: count = 1,
(identity) local= x.x.x.x, remote= y.y.y.y,
local_proxy= 172.20.9.0/255.255.255.0/0/0 (type=4),
remote_proxy= 172.20.8.0/255.255.255.0/0/0 (type=4)
IPSEC(spi_response): getting spi 0x79d3f3bf(2043933631) for SA
IPSEC(key_engine): request timer fired: count = 2,
IPSEC(spi_response): getting spi 0xaa3f5dbd(2856279485) for SA
IPSEC(spi_response): getting spi 0xa22a0c10(2720664592) for SA
IPSEC(spi_response): getting spi 0xef2ba5c0(4012615104) for SA
IPSEC(spi_response): getting spi 0xe9030f5b(3909291867) for SA
IPSEC(spi_response): getting spi 0xf86c4794(4167845780) for SA
remote_proxy= 10.100.8.0/255.255.255.0/0/0 (type=4)
IPSEC(spi_response): getting spi 0xdc627d36(3697442102) for SA
12-27-2007 11:51 AM
ASA, by default, uses PFS group 2 if group is not specified. Whereas PIX 6.X uses PFS group 1 if group is not specified.
So, you need to change the PFS group on any of the devices to match the other.
Hope that helps.
12-27-2007 11:54 AM
Use this on PIX
crypto map
Or on ASA, use :
crypto map
12-27-2007 02:42 PM
I didn't know that ASA uses PFS group 2 as default. I guess you learn something new every day. I'll change that and let you know how it went and if the problem persists.
01-11-2008 12:47 AM
The changing of PFS values on ASA solved the problem. There are no more dropped tunnels.
Thanks for all your help.
