Using VPN as a backup to frame relay connection
I have a central site with 5 remote offices; i'm using Frame Relay to connect the offices to the central site.
I want to user Internet and VPN's to have a backup to the frame relay connections.
What is the best technical solution ???.
Dynamic routing ?
static routing with different weigths ????
GRE tunnels ???
IPSEC tunnels ????
Is it possible ???
thanks in advance
Re: Using VPN as a backup to frame relay connection
general answer; yes, it's possible
how to implement it depends also on your current setup; e.g. are you already using dynamic routing protocols ? does the platform you're using support dynamic routing protocols ?
You must use IPSEC tunnels & may want to use GRE tunnels.
Thanks, for your answer, MARTIJN .
Actually i'm using static routing, and if possible, i would like to continue using it. Statics routes with 0 weigth in the frame relay and static routers with bigger weigth as backup.
I think it's better conceptually to use IPSEC tunnels and not GRE tunnels.
then floating static to VPN tunnel is indeed best solution; should use perfectly.
already found configuration guidelines on Cisco.com?
114
