Using vpn client 3.1 with a cisco 804 isdn router
I am trying to connect with the corporate network using vpn client 3.1 over the internet. I use a cisco 804 isdn router to connect to the internet. I can connect using the vpn dialer but that is far as I can go. I can't ping the corporate server. Everything works fine when I use dial up networking and a modem. I assume the problem is with the setup of the router or the router won't even support the connection. Any ideas?
1 REPLY
Re: Using vpn client 3.1 with a cisco 804 isdn router
Can you make an ipsec tunnel through Cisco804 router or ?
What kind of device you're using at your corporate network ?
91
