Using VPN IP for Static NAT?
Is it possible to use the VPN IP Address on the PIX (the outside interface IP) for Static NAT purposes also?
Let's say i want to host my server 10.1.1.1/24 from internal to external (not using DMZ for this example).
ip address outside 202.1.1.1 255.255.255.248
ip address inside 10.1.1.0 255.255.255.0
global (outside) 1 202.1.1.2
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 202.1.1.1 www 10.1.1.1 www netmask 255.255.255.255
access-list acl_out permit any host 202.1.1.1 eq www
access-group acl_out in interface outside
I'm doing this for my client, I'm worried that if I do like this, I might block VPN traffic. Is there anyway to do this as i'm trying to conserve IP.
(sysopt connection permit-ipsec takes precedence over access-list? If i define an access-list only to permit http traffic to the IP, will it block IKE establishment all together?)
Re: Using VPN IP for Static NAT?
That'll be fine, you can define the outside ACL to only allow port 80, IPsec packets will still come in and be decrypted and sent internally correctly.
Gold
to further conserve public ip, you may even put 202.1.1.1 as the global pat address and it will not affect the vpn and port forwarding.
global (outside) 1 202.1.1.1
each pat address will provide 64,000 connections, thus you may conserve another ip if your client has a small number of user.
267
