Video Conference problem
I purchased a tandberg 1000 and having problems with people from the outside connecting to the video port through a Pix Firewall.
Tandberg support did a trace and looks like the firewall is changing the
IP address 0.0.0.0 and Ip header which causes no video connect.
We have the correct ports open accourding to Tandberg.
I can also connect going out of the firewall. I'm wondering if you have to somehow make the port assigned where the header and address stay's the same.
Tandberg does not know where the issue could be.
Has anyone out there had the same problem.
Re: Video Conference problem
What PIX version are you using? I think you need to be on 6.x for h.323 support.
I have a host in my dmz for which I configured video conferencing and is working fine. I have done following:
fixup protocol h323 1720
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol skinny 2000
access-list acl_out permit tcp any host eq 1503
access-list acl_out permit tcp any host eq h323
access-list acl_out permit tcp any host eq 1731
static (dmz,outside) netmask 255.255.255.255 0 0
Earlier I had PIX6.0 and I was facing lot of problems with video conferencing now with PIX6.1(1) and this configuration it is working.
Althogh I very frequently get following messages in my logs as PIX doesn't like IP options in the IP packet as it considers it a security risk so it discards the packet.
Jan 15 12:48:15 xxxx-1 %PIX-2-106012: Deny IP from to , IP options: "0x14"
Jan 15 12:48:37 xxxx-1 %PIX-2-106012: Deny IP from to , IP options: "0x14"
175
