01-07-2004 02:16 PM - edited 03-09-2019 06:03 AM
I am currently receiving syslog feeds from network devices to my VMS/Security Monitor (2.2/1.2.3 respectively). It's listening on UDP 514 and forwarding to 52514 like it is supposed to. However, where can I view the syslog data that is being received (aside, of course, from looking at the actual file that is created)?
01-09-2004 03:14 AM
First you should add the devices to Sec. Mon, afterwards in the Monitor tab select Events. In the type field (for example for PIX syslogs) select PIX security summary.
Kind regards,
SIMON Janos
01-16-2004 11:46 AM
If you are on a Windows platform you can use the syslog analysis function (in RME) or look at the syslog file directly using your favorite text editor. There is not a way to view the "live" syslog data as it hits the NMS. On UNIX, you should be able to do a "tail -f
