VMS 2.1, Problem Pushing New Configs
When I attempt to push new configs to my appliance sensors (4230s & 4210s) I get the following error message in my audit logs:
RDEP Collector (<sensorname>) parsed an evError: errTransport WebSession::sessionTask(6) TLS connection exception: handshake incomplete.
Can anyone tell me how I might resolve this problem?
1 REPLY
Re: VMS 2.1, Problem Pushing New Configs
Hi Coby,
Couple of things to do;
1. In the IDSMC, Configuration-->Settings-->Object Selector--> Select the sensor--> then from the TOC--> Identification---> Query sensor-->apply.
This will refresh the IDSMC database with the current IDS details.
2. Is the signature version of the IDSMC greater that or equal to that of the sensor?
You might try deleting the sensor and re-adding it into the IDSMC and try the deployment.
Yatin
89
