Community Member
VMS Bundle 2.1 and syslog anaylsis
Under Resource Manager Essentials I cannot get the syslog analysis-> Syslog Collector Status to pull up on the VMS console. I need to check what is successfully sending syslog data to the VMS console. I get a message stating to check the dbEssentials engine is running. I check under the processes location and it says the service is started. Any ideas
1 REPLY
Silver
Re: VMS Bundle 2.1 and syslog anaylsis
Did you try to stop and restart the dbengine? The process is described in length in the document 'How To Re-Initialize the Resource Manager Essentials 3.3 and 3.4 Database'. The document is located at 'http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_configuration_example09186a00800a7652.shtml'. A word of caution though... please be sure of the effects that the restart would have on your network.
101
