VMS upgrade 2.1 to 2.2 - inplace upgrade or full rebuild?
Will the upgrade from 2.1 to 2.2 require me to rebuild the server or is it an in place upgrade or my choice.
If inplace upgrade, will it remove all old components like cspm and replace with new?
  • Other Security Subjects
1 REPLY
Re: VMS upgrade 2.1 to 2.2 - inplace upgrade or full rebuild?
Your choice really, in place upgrade is easiest because yes, it keeps all your old settings that way.
See http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/vpnman/vms_2_2/index.htm for details, go to the Common Services section first and read the upgrading documentation, then you can go to each MC and read it's install section too.
81
