VoIP accounting (too many messages)
Hi all,
I'm trying to start a VoIP accounting on AS5300. A voip call opens 2 accounting sessions and both contain equal information. I do not know how to filter out one of them (they are equal), it's only one needed for accounting. It's not a problem with IOS because Cisco1750 gives the same results.
Here is some brief from config:
aaa new-model
aaa accounting connection h323 stop-only group radius
gw-accounting h323
Does anybody have the same problem? Do you have ideas how to solve it?
Mike
Re: VoIP accounting (too many messages)
When doing VoIP accounting, you'll get one accounting record for each call leg. In a VoIP call you have at least two call legs, one POTS and one TCP/IP. There's no way to not have IOS send out a record for each of these.
You can read more about VoIP accounting here:
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a00800e0db5.shtml
Can I suppress messagess from one call leg or at least destinguish one call leg from another on RADIUS. Nobody needs to make accounting on one event twice.
Here are messages generated on one call:
Mon Oct 28 10:38:13 2002
NAS-IP-Address = 212.69.98.250
NAS-Port-Type = Async
User-Name = ""
NAS-Port-DNIS = "2340133"
Acct-Status-Type = Stop
User-Service = Login-User
Acct-Session-Id = "473/*07:36:40.212 UTC Mon Oct 28 2002/AS5300_GW./D4F6750E E97E11D6 888081FE 44BDB14F/originate/VoIP/*07:36:41.242 UTC Mon Oct 28 2002/*07:36:46.852 UTC Mon Oct 28 2002/10/212.69.98.252/D4F6750E E97E11D6 888081FE 44BDB14F"
Acct-Input-Octets = 2682
Acct-Output-Octets = 2780
Acct-Input-Packets = 137
Acct-Output-Packets = 139
Acct-Session-Time = 6
Acct-Delay-Time = 0
User-Name = ""
Acct-Session-Id = "472/*07:36:40.208 UTC Mon Oct 28 2002/AS5300_GW./D4F6750E E97E11D6 888081FE 44BDB14F/answer/Telephony/*07:36:41.234 UTC Mon Oct 28 2002/*07:36:46.864 UTC Mon Oct 28 2002/10//D4F6750E E97E11D6 888081FE 44BDB14F"
Acct-Input-Octets = 2780
Acct-Output-Octets = 2302
Acct-Input-Packets = 139
Acct-Output-Packets = 118
Acct-Delay-Time = 0
You can't suppress them, but you can distinguish between them. In the Acct-Session-Id attribute, there's a number of different fields separated by slash (/) characters. The 6th and 7th field in this attribute are the origin and the call-leg type.
You can see for one it's originate/VoIP (the VoIP call leg) and for the other it's answer/Telephony (the POTS call leg).
107
