VPDN connection causes router to reboot
Hello all,
I have a Cisco 1710/VPN-9 and everytime a VPDN connection is made externally the router reboots itself. Typically using the Windows 2k Pro VPN client from serveral machines, the client will sit at verifying username and password then the router will reboot. Listed below is the config for my router
Using 1566 out of 29688 bytes
version 12.2
hostname xmain
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username x password 0 x
memory-size iomem 25
ip subnet-zero
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 5
local name x
interface Ethernet0
ip address x.x.x.x 255.255.255.128
ip nat outside
half-duplex
interface FastEthernet0
ip address 10.10.1.110 255.255.255.0
ip nat inside
speed auto
interface Virtual-Template5
ip unnumbered Ethernet0
ip mroute-cache
peer default ip address pool REMOTE
ppp encrypt mppe auto
ppp authentication ms-chap
ip local pool REMOTE 10.10.100.1 10.10.100.254
ip nat inside source route-map NONAT interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
access-list 1 permit 10.10.1.0 0.0.0.255
access-list 121 permit ip 10.10.1.0 0.0.0.255 10.10.2.0 0.0.0.255
access-list 121 permit ip 10.10.1.0 0.0.0.255 10.10.100.0 0.0.0.255
access-list 131 deny ip 10.10.1.0 0.0.0.255 10.10.2.0 0.0.0.255
access-list 131 permit ip 10.10.1.0 0.0.0.255 any
route-map NONAT permit 10
match ip address 131
snmp-server community IDSASTRA RO
snmp-server contact xxxx
snmp-server enable traps tty
line con 0
line aux 0
line vty 0 4
password xxxxx
login
no scheduler allocate
end
1 REPLY
Bronze
Re: VPDN connection causes router to reboot
Are you getting any error messages, that might give us an idea? Try debugging.
85
