VPDN DNIS issues with RADIUS
I'm new to the dial/vpn environment and have come across a problem with regards to VPDN and Radius. I have searched Cisco's documentation, IOS command references and design guides but have not found any mention of the problem I have found.
Since we have enabled VPDN on our Access servers, we have been getting "no such user" errors on our RADIUS server with a username of "dnisxxxxx" where xxxxx is the number that was dialled. so basically, when a user dials in, the Access Server passes the user name to the Radius server and the user gets authenticated, but then the Access server sends ANOTHER username to the RADIUS server of dnis:<number called>. This is seen in the RADIUS debugs:
RADIUS/ENCODE: Attribute has no value set for AAA attribute clid
RADIUS: AAA Unsupported [150] 7
RADIUS: 41 73 79 6E 63 [Async]
RADIUS(00000031): Storing nasport 10 in rad_db
RADIUS(00000031): Config NAS IP: 0.0.0.0
RADIUS/ENCODE(00000031): acct_session_id: 58
RADIUS(00000031): sending
RADIUS/ENCODE: Best Local IP-Address x.x.x.x for Radius-Server x.x.x.x
RADIUS(00000031): Send Access-Request to x.x.x.x:1645 id 21645/37, len 84
RADIUS: authenticator A7 33 C0 3B 13 02 00 88 - 6E 37 25 FD 73 4E 6B FA
RADIUS: Framed-Protocol [7] 6 PPP [1]
RADIUS: User-Name [1] 10 "bob2541"
RADIUS: User-Password [2] 18 *
RADIUS: Called-Station-Id [30] 6 "0027"
RADIUS: NAS-Port-Type [61] 6 Async [0]
RADIUS: NAS-Port [5] 6 10
RADIUS: Service-Type [6] 6 Framed [2]
RADIUS: NAS-IP-Address [4] 6 x.x.x.x
RADIUS: Received from id 21645/37 x.x.x.x:1645, Access-Accept, len 40
RADIUS: authenticator 22 73 01 DD 9E AC 26 80 - 7E 44 DB 11 27 1F EE BD
RADIUS: Framed-IP-Netmask [9] 6 255.255.255.255
RADIUS: Reply-Message [18] 8
RADIUS: 61 6E 6E 65 78 3A [annex:]
RADIUS(00000031): Received from id 21645/37
RADIUS/DECODE: Reply-Message fragments, 6, total 6 bytes
**********Above user authentication successful but now the DNIS authentication***********
RADIUS(00000031): Using existing nas_port 10
RADIUS(00000031): Send Access-Request to x.x.x.x:1645 id 21645/38, len 79
RADIUS: authenticator 63 6B 06 3E B2 B3 7E E8 - 88 9C 45 E8 B5 D5 8B 20
RADIUS: User-Name [1] 11 "dnis:0027"
Service-Type [6] 6 Outbound [5]
RADIUS: Received from id 21645/38 x.x.x.x:1645, Access-Reject, len 34
RADIUS: authenticator 31 5A AE 6F B2 41 82 1C - 35 A4 74 9D 3A 82 23 11
RADIUS: Reply-Message [18] 14
RADIUS: 4E 6F 20 73 75 63 68 20 75 73 65 72 [No such user]
RADIUS(00000031): Received from id 21645/38
RADIUS/DECODE: Reply-Message fragments, 12, total 12 bytes
Can anyone tell me or point me in the right direction on how to stop the Access Server from requesting the dnis authentication? This is causing a LOT of traffic to our RADIUS servers because this happens for every user who dials in. Any help is greatly appreciated.
thanks
Re: VPDN DNIS issues with RADIUS
Normally this is only seen when doing pre-auth, not sure if you're doing that or not.
The global config command 'vpdn authen before-forward' will skip the dnis/domain request, but this is usually seen BEFORE the client username request, not AFTER.
You might also try 'vpdn search-order domain' and see if that helps.
Thank you thank you thank you thank you :)
This was my VPDN config before:
vpdn enable
vpdn authen-before-forward
vpdn authorize directed-request
I have now added the "vpdn search-order domain" command and it's working perfectly. No more dnis.
Thanks again for the help :)
143
